2003 Chevy Tahoe Reduced Engine Power
Had engine replaced in my 2003 Chevy Tahoe 5.3 Flex. It runs perfect. But if i cut on my ac, hold window but down too long or hold door lock button too long i get message reduced engine power. I get error code P1518. (I have a brand new throttle body and a brand new throttle actuator It doesn’t have any trouble starting) I then gotta use my scanner to reset the code. Any suggestions? Thanks
Here's a start. Weak battery is a prime suspect, just because it cranks and starts doesn't mean it's good.
P1518 CHEVROLET code possible causes
- Dead or weak battery
- Faulty Throttle Actuator Control (TAC) module
- Throttle Actuator Control (TAC) module harness is open or shorted
- Throttle Actuator Control (TAC) module circuit poor electrical connection
- Check Throttle Actuator Control (TAC) module connector for water
TXPalerider
Nov 28, 2019 7:49 AM
