2003 Chevy Tahoe Reduced Engine Power
Old Oct 1, 2021 | 12:23 PM
Truckman77's Avatar
Default 2003 Chevy Tahoe Reduced Engine Power
Had engine replaced in my 2003 Chevy Tahoe 5.3 Flex. It runs perfect. But if i cut on my ac, hold window but down too long or hold door lock button too long i get message reduced engine power. I get error code P1518. (I have a brand new throttle body and a brand new throttle actuator It doesn’t have any trouble starting) I then gotta use my scanner to reset the code. Any suggestions? Thanks
Old Oct 2, 2021 | 8:08 AM
repairman54's Avatar
Here's a start. Weak battery is a prime suspect, just because it cranks and starts doesn't mean it's good.
P1518 CHEVROLET code possible causes
  • Dead or weak battery
  • Faulty Throttle Actuator Control (TAC) module
  • Throttle Actuator Control (TAC) module harness is open or shorted
  • Throttle Actuator Control (TAC) module circuit poor electrical connection
  • Check Throttle Actuator Control (TAC) module connector for water
Old Oct 3, 2021 | 10:46 AM
Truckman77's Avatar
Repairman54 you were exactly right. Got a brand new battery and everything is good. Thanks man
Old Oct 3, 2021 | 1:43 PM
Rednucleus's Avatar
Window button was a good clue the battery was tired.
Old Oct 4, 2021 | 10:13 AM
Truckman77's Avatar
I thought it was fixed but its back to doing the same thing. Might be a ground wire
Truckman77
Aug 27, 2021 9:41 AM
Truckman77
Jul 22, 2021 6:07 PM
TXPalerider
Nov 28, 2019 7:49 AM
philsdeuce
Jan 13, 2017 9:59 PM
Crystal Hunt
HHR
Dec 22, 2015 10:37 PM
