2003 K1500 - grinding/rubbing while turning left
Old Oct 17, 2007 | 11:34 AM
julio's Avatar
Default 2003 K1500 - grinding/rubbing while turning left
I am hoping someone can help me diagnose what is causing the following:
Turning the steering wheel to the left cuases 'grinding/rubbing' at certain spots, and it can be heard and felt on the steering wheel.
This onlyhappens at certain points during the turn, not all the time. It doesn't matter if Iturn the steering wheel from the center, or from all the way on the right. It only happens turning left. And it happens in park, drive, and reverse. It is a 2003 suburban with just under 70K miles.
Any ideas? Thanks.
Old Oct 17, 2007 | 3:13 PM
DomesticFan's Avatar
Default RE: 2003 K1500 - grinding/rubbing while turning left
right front wheel bearing. the right wheel bearing takes all the load when the car is left of center and vice-versa
Old Oct 17, 2007 | 6:05 PM
p.hinds's Avatar
seen some gear box cause this,dont think a wheel bearing would grind in park.
Bigdaddy95
19
Sep 3, 2020 5:50 PM
jglm77
10
Feb 17, 2014 9:39 PM
waterwagen
Jan 24, 2008 9:01 PM
waterwagen
Nov 17, 2007 12:20 PM
