2003 Suburban 1500 Brake Line
Hi all - my 2003 Suburban just started leaking brake fluid at the rear driver side. Appears to be leaking near the frame. I assume the rigid line has rotted out. How easy/difficult is it to change the brake line?
Thanks
Thanks
Straightforward repair if you have access. You may need to use aftermarket parts. Then the system gets bled. If this is beyond you, should be like $150 repair at an independent ASE mechanic.
