2003 Suburban 1500 Brake Line
Old Feb 16, 2022 | 7:39 AM
Jason PM's Avatar
Default 2003 Suburban 1500 Brake Line
Hi all - my 2003 Suburban just started leaking brake fluid at the rear driver side. Appears to be leaking near the frame. I assume the rigid line has rotted out. How easy/difficult is it to change the brake line?
Thanks
Old Feb 16, 2022 | 8:12 AM
Cusser's Avatar
Straightforward repair if you have access. You may need to use aftermarket parts. Then the system gets bled. If this is beyond you, should be like $150 repair at an independent ASE mechanic.
Samhilllrocks
Aug 14, 2019 3:33 PM
wbywmu
1988 - 1998 (GMT400)
Jun 8, 2017 11:48 PM
378DRIVER
Nov 17, 2016 8:10 PM
Uncle Wick
Oct 31, 2016 12:07 PM
Unknown1329
Dec 5, 2010 8:04 PM
