2003 Suburban Z71 Chirp noise
Old Sep 20, 2011 | 8:25 PM
sweet1983zz28's Avatar
Exclamation 2003 Suburban Z71 Chirp noise
we have an 03 suburban that makes a chirp noise all the time. we have removed the belts, still makes the noise, replaced main bearings and connecting rod bearings, still makes the noise. really want to fix this problem but cant figure out what it is. any help is greatly appreciated. thanks
Old Sep 21, 2011 | 11:27 AM
slw210's Avatar
Could you describe the noise a little better? Sounds like it could be one of your pulley bearings going out. Most likely a tensioner/idler or altenator.
Old Sep 21, 2011 | 11:42 AM
SWHouston's Avatar
slw, he said he pulled the Belts, that'd eliminate the pulleys and all, but, if I had to guess, I'd say a "dry" Rocker Arm, Oil Seal, maybe even a Motor Mount that's loose ??
Old Sep 22, 2011 | 10:40 AM
slw210's Avatar
Missed that part.
Still hard to say without hearing it.
Old Sep 22, 2011 | 2:20 PM
kevinkpk's Avatar
Does the "chirp" follow rpm? Or moving, not moving? You really need to pinpoint it closer.
rickeyxxx
Apr 17, 2014 9:40 PM
valvano
Sep 3, 2011 4:49 PM
valvano
Aug 7, 2011 5:46 PM
jvela1979
May 26, 2010 2:28 PM
bubba_gump
12
Mar 7, 2008 2:07 PM
