2004 Chevy Tahoe not shifting into overdrive
Old May 31, 2021 | 1:55 PM
Thor529's Avatar
Default 2004 Chevy Tahoe not shifting into overdrive
I have a 2004 Chevy Tahoe. Today I noticed it all of the sudden it would not shift into overdrive. I can manually shift from 1 to 2 to 3 and then into overdrive but when I do the transmission doesn't actually shift into overdrive. It stays in 3rd. It only goes up to 45 or 50 mph at 3500 to 4000 rpm even when I shift it manually. I am leaning more toward the shift solenoid for overdrive. I would like to know if anyone has had this problem and what their fix was. I am fixing to drop the pan and change the solenoid. I will revise this thread if it fixes my problem.
Old Jun 2, 2021 | 8:37 AM
repairman54's Avatar
Get it scanned first before wasting time and money to see what codes may be stored .
Old Jun 29, 2021 | 12:31 AM
KChevy75's Avatar
I know of no situation where this trans would not be able to shift into only 4th gear. no 2nd and 4th means 2-4 band is slipping. No 1st and 4th means Shift A solenoid is bad. No 3rd or 4th means forward sprag is broken. No 2nd, 4th or reverse means broken sunshell.
Sctmcly
Nov 5, 2023 6:51 AM
Thor529
May 31, 2021 1:35 PM
Chevy_man626
Oct 13, 2019 8:53 PM
vincent52100
Jan 11, 2016 1:17 PM
Tom Steinhauer
Aug 4, 2013 2:42 PM
