2004 Suburban questions
Old Aug 18, 2010 | 6:28 PM
qcoleman14's Avatar
Default 2004 Suburban questions
I have a 2004 Suburban with a couple of issues.
The first issue is in regards to the TPMS. I took it to the dealer today and was told the rear two sensors were bad. Is there a fuse related to the TPMS? If so where is located and what number is the fuse. The second question is are there more than just the one horn fuse under the hood? The horn that is related to the keyless entry works but the one on the wheel doesnt. Any suggestions?
Thanks,
qcoleman14
Old Aug 18, 2010 | 7:55 PM
MDTAHOE's Avatar
Professional Mechanic
A fuse would not shut down 2 tire sensor. They are in the wheels. The dealer has a tool that can read the data at each sensor they are probably bad.
Old Aug 18, 2010 | 8:40 PM
the horn for the keyless and the horn on the steering wheel are one and the same.. the horn button/contact in the steering-wheel is probably dirty or bad...
Old Sep 6, 2010 | 1:43 PM
joefink's Avatar
I believe the horn issue is a Service Bulletin. What I found on my 2006 is that the connector under the airbag had started to corrode. I removed the airbag fuse (under the hood), removed the airbag (press through holes on both sides of steering wheel), then took the clip off in the middle that connects to the two rails that make contact for the horn.
I found some corrosion on the contacts for that clip. I emeryed the removed connector, then took some emery cloth and taped it to the end of a Q-tip. I inserted the other end into my cordless drill, then "lightly" cleaned the connection in side the clip. Finally, I cleaned both ends of the connection with electrical cleaner, I used it on the end of another q-tip (I didn't spray it into the steering wheel assembly).
This has worked for me, YMMV.
joe
97burban
Aug 16, 2008 9:44 AM
JLB
Apr 24, 2008 11:45 AM
KGRIFF
Apr 23, 2008 5:54 PM
tlarimer
Feb 1, 2008 3:03 PM
McGuireV10
Jul 28, 2007 9:46 AM
