2004 suburban z71 p0651 and p0452
Old Oct 10, 2020 | 4:43 PM
Jason Kluey's Avatar
Default 2004 suburban z71 p0651 and p0452
I had a P0651 and a P0 452 code so I replaced the fuel pressure sensor with one from O’Reillys 30 minutes later to the check engine light comes back on so I do some more tinkering around can’t figure out anything with my baby so eventually I take it to a shop and they had it for three days after the first day I get a call saying that the mechanic was stumped didn’t know what was causing it there. A few wire issues and the next day they suggested replacing the fuel pump with the OEM one and the fuel pressure sensor with an Oem oneThat cost about 1100 bucks three days later the check engine light comes back on at first it was just a P0651 open voltage circuit be and then just as yesterday but a week later the P0452 is back on it last night on the way home from work tighten fuel Message came on so I tighten that these codes just won’t go away I wonder if anybody’s had this problem before if they could Pass what they know or whatever and let me know how to fix this issue you can email me at jason.kluey@gmail.com
Old Oct 10, 2020 | 8:46 PM
PNW NBS Z71's Avatar
Have you done any other work recently in that area? If the new sensor is good, a 50/50 crapshoot with some aftermarket parts, the rest could be wiring or even a problem at the Powertrain Control.
Old Oct 11, 2020 | 1:16 AM
Default Trouble
Yes I’ve replaced the ac low pressure switch fuel pump was actually the original from 04 with 300k lol new fuel pressure switch new throttle body replaced front seats original ones had no airbags in side and the ones I put in do have air bags I also replaced fuel cap
yet occasionally the tighten fuel cap comes on
The interior light. Flickered last night only time they did that
Ac don’t work any more unless it’s in neutral and I rev it t 2000 rpm
Old Oct 11, 2020 | 4:34 AM
Sounds like a tech needs to get involved and inspect. The a/c problem sounds like it is just low on refrigerant but a/c gauges can be hooked up for a reading. Have you looked thru you tube about the codes you listed?
Mike Rice
Sep 9, 2018 11:08 AM
drew1
Jan 6, 2018 7:05 AM
Waymore
Nov 14, 2017 8:14 PM
tommy gunz
Sep 26, 2017 2:03 PM
stairwayto7
Feb 20, 2013 10:45 PM
