2004 Tahoe - Windshield wipers will not turn off
Old Jan 9, 2007 | 9:43 PM
gturner79's Avatar
Default 2004 Tahoe - Windshield wipers will not turn off
I currently have a problem with my windshield wipers. If I turn them on about half the time they won't turn off when I turn the switch off. It usually happens during the intermittent wiper settings, and they switch to a constant (non-intermittent) mode when they get stuck. The switch is a rotating **** on the turn signal lever. If I turn the vehicle off and leave it off, then they usually turn off the next time I turn the vehicle on. I'm not sure if there is something wrong with the switch, if there is a relay somewhere that has gone bad, or if it is the motor for the wipers. Any ideas???[align=left] [/align]
Old Jan 9, 2007 | 9:51 PM
ZX1100F1's Avatar
Default RE: 2004 Tahoe - Windshield wipers will not turn off
Most likely a faulty multifunction switch (turn signal lever).
Old Apr 13, 2010 | 8:06 PM
tripharris's Avatar
Hey has anyone else had this issue? Our 04 Tahoe is now doing the same thing. I hope it is not the turn lever...that thing is expensive...
Old Apr 14, 2010 | 3:37 PM
jmp2204's Avatar
I had the same issue in my 04 silverado, apparently the relay's (under hood) stick on them , i was told to replace it , but i just removed it and plugged it back in and have never had a problem since (3 years ago) so try your relay
Jessica Turner
Apr 14, 2013 1:11 AM
SabrToothSqrl
Jul 27, 2012 2:02 PM
AustinTahoe
Jan 18, 2012 1:51 PM
dshifflettca
Aug 14, 2011 6:19 PM
