Front Windshield wipers not working
Old Jul 12, 2012 | 9:44 AM
SabrToothSqrl's Avatar
Default warranty
2010 should be under warranty...
Old Jul 12, 2012 | 1:28 PM
Put a volt meter on the wire plug that goes into wiper motor and see if there is voltage going to it. If there is then the motor is probably bad.
Old Jul 27, 2012 | 2:02 PM
Official GM Rep
<!--[if gte mso 9]><xml> <o:CustomDocumentProperties> <o:HTML dt:dt="boolean">1</o:HTML> <oocumentEncoding dt:dt="string">utf-8</oocumentEncoding> </o:CustomDocumentProperties> </xml><![endif]--><!--[if gte mso 9]><xml> <w:WordDocument> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> ponchpadilla, how did things go with the wipers on your 2010 Suburban? Did you visit the dealership about this since it should have been covered under warranty?
Michelle, Chevrolet Customer Service assisting Louis
95chevyTN
Jun 10, 2014 7:00 PM
Jessica Turner
Apr 14, 2013 1:11 AM
AustinTahoe
Jan 18, 2012 1:51 PM
dshifflettca
Aug 14, 2011 6:19 PM
gturner79
Apr 14, 2010 3:37 PM
