2005 Tahoe No crank no start
Old Sep 27, 2022 | 8:18 AM
jaasiel's Avatar
Default 2005 Tahoe No crank no start
Ok guys here's what's going on. I have a 05 Tahoe that I was driving down the road and it died. Pulled to the side of the road and have no crank no start. The check engine light and the abs light comes on when I turn the key, but none of the gauges come on. Checked all the fuses and all have power and battery tested good. Weird thing is when I take the key out after trying to start the dash lights stay on and will not go out until I disconnect the battery.
Old Sep 29, 2022 | 8:55 AM
repairman54's Avatar
I would suspect the ignition switch. Need to diagnose it with a meter and wiring schematic.
Old Jan 2, 2025 | 8:36 PM
Bryan D.'s Avatar
did you ever get this fixed? I have a 2005 that has the same exact symptoms. I do have power at the crank fuse when the ignition is turned to crank (12.5v).
pepperjackom
Jul 31, 2017 6:20 AM
Jwmoore
Feb 8, 2017 10:19 PM
gruņis
Jul 22, 2012 9:57 PM
experimentalist
Nov 29, 2010 6:00 PM
eyeflyfish
Dec 27, 2008 6:50 AM
