2006 6.0L Suburban Misfire and Stumble
Old May 10, 2021 | 10:03 AM
banjolyn's Avatar
Default 2006 6.0L Suburban Misfire and Stumble
Hello Everyone,
I bought a 06 Burb 6.0L about 6 months ago to build a camper truck out of it. This thing is a beast. Didn't have any issues when I bought it, except for an exhaust leak.
Hard start. Runs great for 40 mins, then a hard miss. It will get increasingly worse, sputters and flashes the P0300 for a few seconds, then corrects itself. Other than that, no codes. Idle RPMs drop suddenly to 200, but then they come right back up. Fuel trims while it does this +12 to +13% and air is about 9 g/s. I have been throwing parts at it for months now and each one seems to fix it for a while, but then the misfire comes back.
New parts (previous owner):
Plugs/wires
Cam shaft/lifters
Head gaskets
High volume oil pump
New parts (by me):
Fuel injector cleaner
Cat converters
O2 sensors
Crank relearn
Fuel pump
Coils
ECM flash
It has been at a mechanic for over 5 weeks now and they couldn't figure it out. Only thing they could tell me is that it's mechanically sound and it's only affecting one bank. Best we can figure is a new ECM? Even though it just got flashed?
Please help! I'm so frustrated with this thing, and it's camping season! Any suggestions would be so appreciated.
Old May 11, 2021 | 7:24 AM
repairman54's Avatar
ECM fails are not common but can happen.
Since it runs good for 40 min. I would not rule out the ECM as electronic parts can heat up during usage and start to fail. Reflash will not compensate for a internal part like a chip or transistor inside the ECM breaking down.
Did you change the MAF sensor ? That will affect fuel trims but since you said it's only one bank of the engine getting the miss it seems it's not the culprit.
Old May 11, 2021 | 6:05 PM
banjolyn's Avatar
Thanks for the reply. Didn't change Maf, but I pulled it and cleaned it thoroughly. Checked throttle body and air filter while I was at it, both good to go. I'm honestly at a loss for ideas. I found a ECM, programed to my Vin on ebay. We'll see how it goes.
Old May 11, 2021 | 7:52 PM
hanky's Avatar
Do you know if all the lifters were also replaced when the cam was replaced?
Old May 11, 2021 | 7:55 PM
banjolyn's Avatar
They were, yes.
xrjoe
Mar 24, 2023 4:25 AM
banjolyn
May 7, 2021 1:59 PM
Pride&Joy
Aug 1, 2016 6:54 PM
OtherCarASaab
Apr 15, 2015 8:36 PM
