2006 Suburban Rear AC Issue
Old Jun 22, 2021 | 1:30 PM
AlmostSam's Avatar
Default 2006 Suburban Rear AC Issue
Hello! I’m having an issue with the rear ac in my 2006 Suburban. Here is my dilemma:
Rear AC blowing warm air.
Actuators and blower working correctly. Compressor and front AC and working correctly.
Rear lines hot to the touch.
Evacuated system and replaced orifice tube and expansion valve.
Recharged system.
Issue persists.
Any tips would be greatly appreciated.
Thank you!
Old Jun 22, 2021 | 1:46 PM
you should have one cold line and one hot line at the txvalve at the rear evaporator. the small line should be hot...the larger line cold.
ru on the correct 2 lines ie not the rear heater core lines.
Old Jun 22, 2021 | 2:10 PM
AlmostSam's Avatar
Thank you for checking. Yes, I’ve located the correct lines. The large line is now warm to the touch, whereas before, it was hot. I’m guessing there’s still some restriction in the line somewhere. Maybe a faulty part with the new expansion valve.
Old Jun 23, 2021 | 9:09 AM
repairman54's Avatar
Did you recharge the system by weight of the 134 measuring the charge with a scale ?
ntheath
Aug 28, 2020 3:36 PM
rgpinder
Apr 28, 2016 8:30 AM
Eric Althouse
Sep 15, 2014 5:33 AM
bathgate12
May 16, 2014 4:25 PM
speedracer50
Jun 15, 2013 10:32 AM
