2006 Tahoe z71 sunroof
Old Jul 6, 2011 | 11:10 PM
duckmanco's Avatar
Default 2006 Tahoe z71 sunroof
Anyone able to tell me where the sunroof drain lines end on a 2006 z71 Tahoe? The truck has been through two severe rain storms and is parked on a downward slope in my driveway. After each storm, the carpet on the passenger side nearest the door jamb is wet but I'm not able to find where the water is coming in. Any help on where the drain lines are so I can start by cleaning them would be appreciated. Thanks
Old Jul 7, 2011 | 9:09 AM
Default 2006 Sunroof Housing Front Drain Hose
This doesn't say where they end but it might give you some guidance as to where to look for them...
Service Information
2006 Chevrolet Tahoe - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 740594
Sunroof Housing Front Drain Hose Replacement
Removal Procedure
Remove the garnish molding/windshield pillar. Refer to Windshield Pillar Garnish Molding Replacement in Interior Trim.
Remove the sunshades. Refer to Sunshade Replacement in Interior Trim.
Pull down the corner of the headliner.
Remove the hose from module nozzle.
Remove the hose from the clip.
Remove the hose.
Installation Procedure
Install the hose.
Install the hose to clip.
Install the hose to module nozzle.
Be sure the seal is fully seated to plenum and hose is bottomed out against nozzle.
Inspect for kinks in the hose.
Push up the corner of headliner.
Install the sunshades. Refer to Sunshade Replacement in Interior Trim.
Install the garnish molding/windshield pillar. Refer to Windshield Pillar Garnish Molding Replacement in Interior Trim.
Old Jul 7, 2011 | 9:11 AM
Default Sunroof Housing Rear Drain Hose
The rear one
Service Information
2006 Chevrolet Tahoe - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 740595
Sunroof Housing Rear Drain Hose Replacement
Removal Procedure
Remove the center pillar trim. Refer to Center Pillar Garnish Molding Replacement in Interior Trim.
Remove the headliner. Refer to Headlining Trim Panel Replacement .
Remove the drain hose from the nozzles rear, corner and side, assuring butyl tape is removed.
Remove the clip retaining hose to sheet metal.
Remove the grommet from the sealer plate.
Pull the hose away from sheet metal where attached with butyl tape.
Remove the hose.
Install the hose.
Re-locate the hose to sheet metal where attached with butyl tape.
Install the grommet to sealer plate.
Install the clip retaining hose to the sheet metal.
Install the hose to nozzles rear, corner and side, assure butyl tape is in position.
Install the headliner. Refer to Headlining Trim Panel Replacement in Interior Trim.
Install the center pillar trim. Refer to Center Pillar Garnish Molding Replacement in Interior Trim.
Old Jul 7, 2011 | 10:07 AM
duckmanco's Avatar
Thanks so much for the reply, quite helpful. I'm imagining that pulling off the trim pieces is literally just pulling them off the clips and not some other special process right?
Old Jul 7, 2011 | 10:19 AM
It should be, you local auto parts store as well as Amazon.com have some tools that make removing body panels and molding easier....
mmjapc
Apr 4, 2019 4:43 PM
ShakeyMistake
Apr 4, 2019 1:20 PM
sjt4718
Jul 9, 2015 8:28 AM
gearman
Feb 8, 2010 4:17 PM
d1nonly34
Dec 2, 2008 9:33 PM
