2007 Chevy Silverado 1500 4 wheel drive. Low oil pressure
Old Dec 27, 2017 | 3:29 PM
Mmillard's Avatar
Default 2007 Chevy Silverado 1500 4 wheel drive. Low oil pressure
2007 Chevy Silverado 1500 4 WD. Low oil pressure warning comes on. Stop engine warning comes on. Check engine light comes on. Some ticking noise is heard. What are some ways to check out a fix for this
Old Dec 27, 2017 | 3:45 PM
kevinkpk's Avatar
I'd start with checking the oil dip stick
Old Dec 27, 2017 | 4:19 PM
Mmillard's Avatar
Registers full
Old Dec 27, 2017 | 5:11 PM
kevinkpk's Avatar
Is it "decent" oil? When was it changed? Has it had regular oil changes?
Old Dec 27, 2017 | 5:35 PM
Rednucleus's Avatar
What mileage on motor and what is your oil pressure reading on the gauge? Sounds like it's time to tow it to a reputable mechanic vs running it anymore.
Old Dec 27, 2017 | 5:54 PM
Mmillard's Avatar
200,000 mosyly highway miles. Oil changed every 2 to 3k miles. Just started happening withvthe onset of negative 15degrees weather
Old Dec 27, 2017 | 6:22 PM
kevinkpk's Avatar
What weight oil?
Old Dec 27, 2017 | 6:48 PM
Mmillard's Avatar
Kendal 10w30
Old Dec 28, 2017 | 12:19 AM
Suburban Dude's Avatar
First of all you need to decide what your goal is. Your motor has 200,000 miles which is a pretty good run. Are you planning on keeping it until you get 250,000 miles? Or perhaps 300,000 miles? Given the long run, I would recommend switching to 10W-40 oil and then start planning on getting a new or low mileage truck.
If the oil pressure does’t improve you might want to change your oil pressure sensor and screen.
SD
