2007 Chevy Tahoe Air Conditioning Not Working
Old Aug 7, 2012 | 1:03 PM
rnorman4's Avatar
Default 2007 Chevy Tahoe Air Conditioning Not Working
Hi, my A/C is blowing only warm air. The clutch kicks in every 20 seconds or so and then out again. I bought a recharge kit and connected the quick-coupler to what I figure is the low side port (see picture). The pressure with the engine off is already in the "yellow" on this gauge which seems to be around 55psi. Is the system low on refrigerant? What should I do next?
Thanks!!!
Attached Thumbnails 2007 Chevy Tahoe Air Conditioning Not Working-dsc02456.jpg
Old Aug 7, 2012 | 1:04 PM
rnorman4's Avatar
Default Forgot to mention...haven't yet punctured the can.
Old Aug 7, 2012 | 1:23 PM
SabrToothSqrl's Avatar
Default engine
i thought it had to be ON to get an accurate reading?
Old Aug 7, 2012 | 2:25 PM
rnorman4's Avatar
Default Am I on the low side of the A/C?
I thought so too, but assuming I'm on the low side (if anyone knows from the picture?) and it's reading 55psi, wouldn't the pressure increase if I turn it (the A/C) on? 55psi is already in the yellow, the red zone would possibly rupture the can.
Does anyone know if I'm on the low side from the picture?
Old Aug 7, 2012 | 3:09 PM
kevinkpk's Avatar
You see that black cap on the tubing line? Thats where you need to couple to.With engine running, ac on, look at where the guage is.
Old Aug 7, 2012 | 3:28 PM
55 psi on the lo side seems a little high but is also dependent upon ambient temp. What's the high side read?
Old Aug 7, 2012 | 3:29 PM
rnorman4's Avatar
Default High side, low side?
Not sure, can anyone tell from the picture, am I even plugged into the low side?
Old Aug 7, 2012 | 4:04 PM
kevinkpk's Avatar
read the replies.
Old Aug 7, 2012 | 4:13 PM
kevinkpk's Avatar
He should be downstream of the orfice, the orfice might be the issue with a high suction pressure. Too much freon has the same effect as too low freon. It might be the high pressure cutout shutting out the compressor clutch.
rnorman4's Avatar
Originally Posted by kevinkpk
read the replies.
Hey kevinkpk, I assume you are telling me I'm currently plugged into the high side? Yes/No??
And that I should plug into the other port with the black cap on which the recharge kit doesn't fit onto? Maybe I need an adapter to get onto it?
