2007 Keyless Entry Remote Reprogram??
Old Jan 22, 2007 | 11:25 AM
07HoeDown's Avatar
Default 2007 Keyless Entry Remote Reprogram??
Hey guys,
I am new to this forum, I just recently purchased a Black 2007 Tahoe LS 2WD. I would liketo see if anyone knew how to reprogram the keyless remotes since the dealer didnt do it when I purchased the car and asked me to come back during business hours. I dont feel like waiting for an hour or so while they reprogram them whenI can do it myself. Any help would be greatly appreciated it.
Frank
Old Jan 22, 2007 | 1:42 PM
ZX1100F1's Avatar
Default RE: 2007 Keyless Entry Remote Reprogram??
Relearn Remote Key
This display allows you to match Remote Keyless Entry (RKE) transmitters to your vehicle. To match an RKE transmitter to your vehicle, do the following:
[ol]Press the vehicle information button until PRESS TO RELEARN REMOTE KEY displays.
Press the set/reset button until REMOTE KEY LEARNING ACTIVE is displayed.
Press and hold the lock and unlock buttons on the first transmitter at the same time for about 15seconds.
On vehicles with memory recall seats, the first transmitter learned will match driver1 and the second will match driver2.
A chime will sound indicating that the transmitter is matched.
To match additional transmitters at this time, repeat Step3.
Each vehicle can have a maximum of eight transmitters matched to it.
To exit the programming mode, you must cycle the key to LOCK. [/ol]
Old Jan 22, 2007 | 1:52 PM
07HoeDown's Avatar
Thanks so much I will try this...
Old Jan 22, 2007 | 2:19 PM
07HoeDown's Avatar
It worked I appreciate it..
Old Jan 22, 2007 | 4:17 PM
ZX1100F1's Avatar
Welcome aboard and you are most welcome.
Old Jan 5, 2008 | 8:19 AM
calientecafe's Avatar
I did this and it beeped twice but still didnt work?
What does it mean by "cycle the key to lock"?
Old Jan 5, 2008 | 8:34 AM
ZX1100F1's Avatar
It means to turn the ignition to OFF and remove the key.
Old Jan 5, 2008 | 1:14 PM
thanks
Old Jan 7, 2008 | 7:14 PM
I did all this and it beeped and it still wouldnt unlock the vehicle. Neither of the transmitters work and I changed batteries also? Anyone knows what wrong?
Old Jan 8, 2008 | 4:18 PM
ZX1100F1's Avatar
There is a TSB on some faulty transmitters for the factory, have your dealer check if your Tahoe is effected.
