2007 Tahoe Cabin Air Filter
Old Apr 22, 2015 | 9:35 PM
  #21
Got the cabin filter and cap in the mail Monday, instructions are pretty good, will give it a go this week if the weather holds out and will post pictures..
Old Apr 24, 2015 | 10:02 AM
  #22
Got'er done yesterday...
The instructions are clear, they recommend using a box cutter to cut along the scored area to get the filler piece out... I found that nearly impossible to do while leaving the kick panel/beauty cover in place as they recommend, and even with a brand new sharp blade in my utility knife it was a bear and I ended up slipping out of the grove marring up the seat and area....
I recommend removing the kick panel/shield completely, its a bit more of an extra step but it makes the area much more work-able...
To get access to the last screw of the kick panel you will need to remove the cover piece of the center console but it removes easily.
The other item I removed was the blower motor resistor as it also gave more room and also removed it and the wires from any possible damage while cutting...
Something I wish I would have noticed while working and had done, was cleaning the evaporator, it was only after seeing the pictures I took that I saw the brown dust/dirt build up on it... I may revisit this in the coming weeks
I used a oscillating cut out tool I got from Harbor Fright... this made the cutting a whole lot easier, but do be very careful not to go to deep or too wide and damage your evaporator!
Attached Thumbnails 2007 Tahoe Cabin Air Filter-remove-panel.jpg   2007 Tahoe Cabin Air Filter-more-access-.jpg   2007 Tahoe Cabin Air Filter-remove-blower-resistor.jpg   2007 Tahoe Cabin Air Filter-cutting-tool.jpg   2007 Tahoe Cabin Air Filter-insert-folding-filter.jpg
Old Apr 24, 2015 | 10:05 AM
  #23
And finally the all done, sans the kick cover being in place.. note the filter has tabs that should be left accessible for easier removal at change time...
I will probably put this on a annual to 18 mo change out basis due to the accessibility..
Old Apr 24, 2015 | 3:04 PM
  #24
{tpc}'s Avatar
Nice job and pics!
Old Apr 27, 2015 | 7:11 AM
  #25
SabrToothSqrl's Avatar
Default carpet
that is some white carpet!
Old Apr 27, 2015 | 7:58 AM
  #26
I think the camera flash enhanced it, though I do have the titanium interior , its more of a silver / light gray
Old Aug 11, 2017 | 2:22 PM
  #27
chuckb's Avatar
Exclamation Mold Growth
To anyone one that has retrofit the cabin air filter, caution, their more than likely will be mold growth! I noticed an odor and when I cut open the compartment, it had standing water and mold growth throughout (pictures attached). I had it steam cleaned to get the majority of the growth out. GM informed me that they would not be able to "assist" me with the necessary sanitation because apparently I was the first person with this issue.
My understanding is that they have not equipped cabin air filters from ~2005 and on, so I have a hard time believing no other similar model does not have the same issue.
I have since filed a complaint with the National Highway Safety Administration, but feel nothing with come of it unless more people are made aware of the issue and report it to https://www.nhtsa.gov/ Please, if you retrofit and notice mold growth or know anyone who may also have a similar vehicle, to post the issue on the NHTSA website so that we may all live a healthier life.
Thanks in advance.
Chuck
Attached Thumbnails 2007 Tahoe Cabin Air Filter-img_0231-1-.jpg   2007 Tahoe Cabin Air Filter-img_0233-1-.jpg   2007 Tahoe Cabin Air Filter-img_0230-1-.jpg   2007 Tahoe Cabin Air Filter-img_0236-1-.jpg   2007 Tahoe Cabin Air Filter-img_0237-1-.jpg
Old Aug 14, 2017 | 7:46 AM
  #28
I guess the real question... does the 'new' Tahoe have one factory? 2014 was it?
Old Aug 18, 2017 | 3:34 PM
  #29
I'm happy with my aftermarket add of the cabin filter, the replacement filters are WAY over priced at ~$30 for the carbon ones. I do like that I can now access and clean the evaporator to address any mold or mildew. I have not noticed mold but have noticed general crud which I guess is fine particles that have collected on the moisture of the eveap fins...
I was going to try a cleaner
Lubeguard Lubeguard
this fall
Old Jul 30, 2018 | 2:20 PM
  #30
DaveD44's Avatar
Originally Posted by in2pro
I was going to try a cleaner Lubeguard this fall
This thread hasn't been active for awhile, but hopefully it is still being monitored. I recently started noticing a moldy odor in the cabin of my 2013 Tahoe and this has to be the cause, since the Tahoe stays clean and dry and lives in a garage, and this summer is extremely humid on the east coast, with mold and mildew sprouting up everywhere. I pulled the kick plate off and looked at the HVAC unit. It appears that the filter retrofit will be relatively easy to do, so I plan to order one. I will first have my dealer enable the Afterblow option,then I will clean the evaporator core, then install the filter. I removed the motor and resistor/heat sink unit and could see the evaporator core through the heat sink opening. It looks only slightly dirty, but it doesn't take much dirt to grow mold. BTW, I had this problem in my Corvette perhaps ten years ago and the dealer installed a module that did the same thing as today's afterblow option--it turned on the fan sometime after the engine was stopped to dry out the evaporator core and area. It worked somewhat. I also plan to have the Afterblow option enabled in my new Cadillac XT5.
So how do these cleaners work? Hopefully they don't over-deodorize the cabin, as I find perfumes that cover up odors instead of eliminating the cause kind of sickening in themselves. I'm hoping that cleaning the core then installing a filter to prevent much additional dust from entering, plus enabling the afterblow option, will permanently solve the problem. I'm planning to use Klima-Cleaner.
But my main question has to do with the best spot to insert the A/C cleaner. It appears that that spot would be the rectangular hole where the heat sink is mounted, since it is very close to the evaporator core and I could get the majority of the cleaner where it counts, towards the bottom of the core and the drain below it. I will probably tape the hole around the cleaner insert tube so I would not have cleaner all over the cabin floor. Comments?
