2007 Tahoe Ls 4.8
Old Aug 17, 2015 | 11:30 PM
Sigfrido85's Avatar
Default 2007 Tahoe Ls 4.8
Need help I have a 2007 Tahoe ls 4.8l and I have a 5700lb camper just wanted to know if I can tow it, if not what can I do . Thank you,,,
Old Aug 17, 2015 | 11:33 PM
Rednucleus's Avatar
Check your owners manual yet?
Any kind of towing package?
Old Aug 17, 2015 | 11:40 PM
Sigfrido85's Avatar
It didn't come with it, but I'll been looking on the Internet . I sometimes say 4500lb 6500lb 7100 I'm about to have a hard attack lol the only reason I'll buy it was to pull the camper , but I think the said it can pull it just to sale it , thank you for answer me back I'm new on all this .
Old Aug 17, 2015 | 11:55 PM
Rednucleus's Avatar
Bought from a chevy dealer?
Old Aug 18, 2015 | 12:32 PM
SabrToothSqrl's Avatar
Towing 6k w/my 5.3 isn't exactly fast. I'm not sure how the 4.8 will take it...
https://www.google.com/search?q=2007...utf-8&oe=utf-8
Google says.... 4500 lbs.
So... no.
Old Aug 18, 2015 | 1:34 PM
intheburbs's Avatar
The correct answer is, "it depends."
It depends on your axle ratio. If you have the 3.23 rear, your max is 4,200 lbs. If you have the 3.73 rear, your max is 6,200 lbs.
Check the glove box sticker - look for code GT4; that's the 3.73 rear. I don't even know the code for the 3.23 rear.
Even if you do have the 3.73, a trailer that weight is going to be a handful, and you're not going to have much extra payload for passengers and gear.
SOURCE
Old Aug 19, 2015 | 3:05 PM
GT4 Rear axle, 3.73 ratio
GT5 Rear axle, 4.10 ratio
GU5 Rear axle, 3.23 ratio
GU6 Rear axle, 3.42 ratio
I'd say 6,200 is really pushing it, if you are going mostly flat land, hilly terrain, but not mountainous and less than 600-800 miles and only doing it a few times a year probably okay, but I agree with STS's assessment of 4500 being the safe bet...
Watch your transmission temp and give it a try with your 5700 the truck will let you know...
For the most part with your set up, its biggest down side will be slower maximum speeds
I'll throw in the caveat, that if you have too low numerically, of a gear ratio in the rear you could thrash the rear end... (3.08 is a no no...)
Old Aug 19, 2015 | 4:14 PM
Sigfrido85's Avatar
Thank you all for this info, it help me a lot , but what you guys think about using the weight destribution hitch ? Will that help me on towing lil more?
Old Aug 19, 2015 | 4:22 PM
Sigfrido85's Avatar
https://chevroletforum.com/forum/vindecoder.php?vin=1GNFC13C37R265859
Old Aug 19, 2015 | 5:42 PM
intheburbs's Avatar
Weight distribution doesn't increase your towing capacity. It simply makes the tow vehicle more stable when towing a heavy trailer.
The sticker on your receiver likely looks like this:
So if your trailer weighs more than 5,000 lbs, you need to be using weight distribution.
When I attach my largest trailer without connecting the weight bars, it's lifting 500 lbs off my front wheels. That means the front wheels have less grip for emergency maneuvers, and my steering will be lighter and more wiggly.
