2007 Tahoe LTZ won't start
Old Sep 2, 2015 | 10:48 AM
  #21
Typerod's Avatar
15 Year Member
UPDATE: Its been almost 2 weeks since I put the starter in and have had not one single no start issue. I think its safe to say it was a bad starter. Thanks to all who helped!
Old Dec 17, 2015 | 9:54 AM
  #22
Typerod's Avatar
15 Year Member
UPDATE: My wife said last night the car wouldn't start, she turned the key and no cranking from the engine, but the normal dash lights were on. She took the key out and tried starting it again and it fired right up. I hope this was just a fluke, I don't think it is, but I can hope! lol! Its about been about 7k miles since I did the replacement a few months ago. I'll keep this update. I think I'll order the starter relay like in2pro suggested, but never got around to ordering.
Old Dec 18, 2015 | 10:44 AM
  #23
I have had this happen in the past but very infrequently on my 07 we are talking less than a handful in 8 years, and honestly I think it might be from putting key in and turning the ignition too fast or faster than the VAT or BCM can read the key as it's always started the second time and don't remove the key but simple turn it back and then crank again, giving the system time to wake up and read the key...
Old Dec 18, 2015 | 12:34 PM
  #24
Typerod's Avatar
15 Year Member
Thanks for the info! I will ask her to do that next time if it happens. Is it safe to say that the transponder in the key will need to be replaced due to an internal battery?
Old Dec 18, 2015 | 4:49 PM
  #25
No, I don't think at least in what I have seen, there is anything that needs to be done other than try a 1 mississippi count after putting the key in the ignition before turning it
Old Dec 18, 2015 | 8:15 PM
  #26
Typerod's Avatar
15 Year Member
lol! will do, Thanks!
Old Dec 4, 2016 | 12:59 AM
  #27
mheckathorn's Avatar
Just had the same thing occur with my Tahoe. I replaced the starter and still the same single "click". Checked the relay and it is functioning properly. I'm out of options of what else it could be.
Old Dec 4, 2016 | 10:48 AM
  #28
Welcome to the forum,
Check the battery cable to the starter thoroughly for any corrosion or poor connection, look for swelling in any of the wire jacket... if you aren't getting enough current to the starter it won't start, also consider checking the battery out...The 07's are terribly sensitive to even the slightest of low voltage on the battery.
Old Dec 24, 2017 | 7:34 PM
  #29
robandzoe's Avatar
Any more updates on this.. my 2007 Suburban just started acting up like this! Thanks in advance.
dusty6
May 24, 2021 6:05 PM
Turbogarrett
Jan 23, 2013 10:00 AM
guvner
Nov 9, 2012 1:21 PM
Alfordvette
Jan 5, 2012 7:17 PM
bracca
Jul 12, 2009 6:14 PM
