2007 LTZ Tahoe remote start has quit...
Old Nov 8, 2012 | 1:18 AM
guvner's Avatar
Default 2007 LTZ Tahoe remote start has quit...
You can get the lights to turn on and react to your desire for a remote start but you just hear some clicking and it's done. Any ideas on what to look for here? Car starts fine with key.
Thanks... Gary
Old Nov 9, 2012 | 1:04 PM
Official GM Rep
Thanks... Gary
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> guvner,
This issue may be related to the ignition module and/or wire. This is just a suggestion, it is not meant as a diagnosis. I recommend having the vehicle inspected by a certified technician for an official diagnosis.
Please keep us posted.
Louis
GM Customer Service
Old Nov 9, 2012 | 1:19 PM
Do you have any check engine lights on? I THINK if a service light is on the remote start won't work... don't quote me on that but it seems reasonable...
Old Nov 9, 2012 | 1:21 PM
Default Remote Start won't work possible causes
Ah what do you know that is the first one on the list
The RVS system will not operate if any of the following conditions are present:
• A current vehicle DTC that illuminates the malfunction indicator lamp (MIL)
• The vehicle is in valet mode.
• More than 2 remote starts have been attempted.
• The hazard switch is in the ON position.
• A current hazard switch DTC is set.
• The vehicle hood is ajar.
• A current hood ajar DTC is set.
• The CTD system detects an alarm trigger. (Content Theft Deterrent )
• Excessive engine RPM
• Excessive coolant temperature
• Accelerator pedal position greater than 0 percent
• Vehicle not in park
• Vehicle theft deterrent malfunction
• A current automatic transmission shift lock control system DRC is set.
• A vehicle speed sensor signal is detected by the ECM.
Circuit/System Verification
Verify that RVS is enabled in the vehicle driver information center (DIC).
⇒ If RVS is not enabled, use the DIC to turn on RVS functionality.
Verify that the keyless entry functions operate with all available keyless entry transmitters.
⇒ If the keyless entry system does not function properly with all available transmitters, refer to Keyless Entry System Inoperative .
With a scan tool, verify that no RVS Disable History is present.
⇒ If RVS disable history is present, refer to the applicable subsection in which the failure occurred.
With a scan tool, verify that there are no Current CTD Triggers present.
⇒ If a CTD trigger exists, refer to Content Theft Deterrent Malfunction .
bamafutbal
Sep 20, 2024 5:56 PM
dusty6
May 24, 2021 6:05 PM
ceckrx1
Feb 19, 2013 5:42 PM
Kay-G
Oct 19, 2010 12:56 PM
jeff6898
Sep 8, 2009 2:23 PM
