2008 avlanche 2wd LTZ - service suspension message
Old Nov 6, 2013 | 8:09 PM
4x4tx's Avatar
Default 2008 avlanche 2wd LTZ - service suspension message
Just started getting this this week....any ideas where to start? Went to autozone to get them to run a code and nothing??
Old Nov 6, 2013 | 11:03 PM
Tech's Avatar
Take to dealer. I don't think autozone scanners can pull codes out of electronic brake control module or the electronic suspension control module. That message could mean lots of things. But there is an issue in the system and you should have a dealer check in to it.
Old Nov 7, 2013 | 9:56 AM
4x4tx's Avatar
Is it most likely related the compressor on the autoride system?
Old Nov 9, 2013 | 11:43 AM
Tech's Avatar
Yes that is typically what it is related to. The exhaust valves on the compressors go bad.
Old Dec 27, 2013 | 5:49 PM
hvychevy08's Avatar
Hello, I'm getting the same message on my 08 Tahoe 4x4 with 49,700 miles. Is there anything else besides the compressor that may go bad to give you this message? It seems that when I hit a pothole I hear a bang coming from the right front, as if the shocks or something extend to their limit and I'm also getting a little sway in the front at higher speeds!
ie: fuses, relays etc
Old Dec 27, 2013 | 9:56 PM
trainwreck91's Avatar
could also be bad air shocks. LTZ have air ride and the bags could be leaking. you should hear the compressor running a few seconds after you start the vehicle. if you don't hear it then more than likely it went bad. but it could be due to leaky air shocks. which would cause the compressor to constantly run and burn out. new shocks are a pretty penny but fairly easy to replace if you're handy.
Old Dec 28, 2013 | 7:33 AM
hvychevy08's Avatar
Great, thanks. I'll have the shocks checked out as well as the compressor. The only thing I hear at start up is the fuel pump at this point. Have a good one!
Old Jun 23, 2014 | 9:00 PM
4x4tx's Avatar
Mine turned out to be a bad front shock...in fact it was broke..replaced and code went away
Rich2007Z71
Feb 6, 2020 1:59 AM
Boss' Ride
Nov 14, 2012 2:21 PM
Jamie_s_72
Jun 4, 2012 11:20 AM
RoTo
Aug 18, 2011 8:21 PM
edcorsaro
Aug 21, 2007 8:52 AM
