2008 suburban with 40,000 miles oil change
Old Nov 17, 2009 | 9:48 PM
pacman13's Avatar
Default 2008 suburban with 40,000 miles oil change
2008 suburban with 40,000 miles on it, would it be ok to switch to synthetic oil? thanks
Old Nov 17, 2009 | 10:16 PM
MDTAHOE's Avatar
Professional Mechanic
Only if you want your engine to last longer. You can switch to synthetic any time,
Old Nov 18, 2009 | 7:23 AM
pacman13's Avatar
thanks, because i read a couple of threat and they said it might cause leakage. so i'm kind of afraid.
Old Nov 18, 2009 | 9:50 PM
MDTAHOE's Avatar
Synthetic oil does not cause leaks. If a engine already leaks oil it will leak worse. This is because the molecules are smaller and the oil is more slippery.
Old Nov 18, 2009 | 10:02 PM
pacman13's Avatar
[quote=MDTAHOE;121037]Synthetic oil does not cause leaks. If a engine already leaks oil it will leak worse. This is because the molecules are smaller and the oil is more slippery.[/quo
thanks for clarified that, switching to mobil 1 this weekend.
Brew154
Aug 3, 2015 9:13 AM
shepherdsflock
Mar 17, 2015 6:21 PM
jayman1967
Sonic (Aveo)
Aug 23, 2013 1:39 AM
Mille Racer 69
Nov 18, 2012 5:43 PM
MoJames
Feb 9, 2010 2:43 PM
