2008 suburban brake controller
Old Aug 6, 2021 | 5:17 PM
cqfarm123's Avatar
Default 2008 suburban brake controller
I have installed the wiring to controller correctly and I have attached the two red wires under the hood to the poles on the breaker box. The controller comes on but says no connection to trailer. The same trailer and same brake controller work fine on a different vehicle so it is something with the suburban. Any idea what could be causing the connection to trailer issue or how to troubleshoot it?
The 7 pole plug receptor looks good, has a cover, and is not rusty, etc.
Old Aug 7, 2021 | 12:02 AM
check for power at the 7 pin connector....determine what is missing. they have led trailer pin connector testers for $20
MaxxHaul 50155 7-Way Blade Trailer Wiring Tester, Wiring - Amazon Canada MaxxHaul 50155 7-Way Blade Trailer Wiring Tester, Wiring - Amazon Canada
Once you know what is missing...start tracing wires
did you need to install a fuse at the ubec ="breaker box"? for the stud you should have power at the stud
you spliced into the blunt cut wiring under the dash to the 4 pins of the brake controller....or did you splice into a factory plug that connects the the under dash fuse box
Old Aug 8, 2021 | 2:36 PM
cqfarm123's Avatar
Thanks, very helpful. I did that and everything lights up as it should so I am at a loss. Same controller and trailer work fine on different vehicle. Any ideas?
Old Aug 8, 2021 | 8:02 PM
then check for power coming out of the trailer connector. verify truck grd has no resistance to grd.
DDozier234
Aug 6, 2024 1:42 PM
Jason PM
Aug 1, 2021 1:03 PM
humnbass
May 29, 2015 10:39 PM
sswarin
10
Apr 1, 2010 2:23 AM
dHoleman
Jun 27, 2007 9:43 AM
