2008 Tahoe LTZ front a/c controls not working
Hey everyone,
This is my first post here. This morning I remote started my Tahoe and when I got in and put the key in the ignition and started driving I noticed that my a/c controls were not working. The a/c display is black and none of the buttons controlling the a/c were working. The heat was blowing at full blast (the setting I had it on when previously in the car). Everything else electrically seemed to be working fine in the vehicle however I did not check the rear controls.
I turned off the vehicle and restarted it and still had the same issue.
Any suggestions of what might be causing this?
Thanks!
Thanks!
The problem you are experiencing is probably tied to the remote start. As you know when you remote start the vehicle, all of the dash gauges and HVAC controls appear not to have power, as they do when the vehicle has the key in the ignition. However, when you put the key in the ignition and turn it on, everything should come to life.
If it continues, you may want to visit your dealer for a diagnosis. It may be software related.
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Jperki17,
I’m sorry you experienced this issue. “mulmur1” makes a great point. Please keep us posted if you experience this issue again.
Feel free to contact me privately if you have additional questions or concerns.
Louis
GM Customer Service
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Jperki17,I’m sorry you experienced this issue. “mulmur1” makes a great point. Please keep us posted if you experience this issue again.
Louis
GM Customer Service
dcok4744
Feb 10, 2014 7:05 PM
DarrolBlattel
Mar 20, 2013 1:10 AM
bamafutbal
Sep 16, 2012 7:51 AM
