2009 Suburban AC problem
Old Aug 22, 2010 | 9:40 PM
grschumann's Avatar
Default 2009 Suburban AC problem
My AC leaks water on the inside of the car after driving it for 2 hours, the dealership can not figure out what the problem is, I have had it there 5 times. They said they also have had a Tahoe there with the same issue. Has anyone else had this problem?
Old Aug 22, 2010 | 10:21 PM
Welcome to the forum,
Do you have the rear A/C?
is it leaking in the front or rear?
any leak would have to be the inability to drain away the condensation build up... the drains ways are blocked or plugged most likely but more info is needed on the where and when...
Old Aug 24, 2010 | 12:20 AM
Ditto. There's usually a rubber tube w/ a pinched end on the bottom of the evaporator cases that allow the condensate to drain out. Usually get plugged from accumulated dust that turns to mud plus any other debris that gets sucked in.
jtdreiki
Sonic (Aveo)
24
Mar 8, 2017 11:13 AM
bcoth18
Cobalt
Jan 28, 2015 10:51 PM
lockman
Jul 23, 2009 9:57 AM
carolelannerd
May 28, 2009 4:12 PM
