Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
2009 Cobalt Headlight problem
Old Jun 20, 2010 | 11:27 AM
bcoth18's Avatar
Default 2009 Cobalt Headlight problem
While driving home passenger side headlights are very dim when turning on high beam parking lights and headlights are dim. Driver side is working fine Any ideas I thought ground wire if anyone has diagram Thanks
Old Jun 22, 2010 | 1:26 PM
Official GM Rep
Personally I would suggest having this work done at a dealership. You have the 3 year 36,000 mile bumper to bumper warranty and the 5 year 100,000 mile powertrain warranty. You should be covered for a fix of this type under normal circumstances. I hope this information helps you.
Jeff Morris, Chevrolet Customer Service
Old Aug 26, 2012 | 10:26 AM
Lesley Finelli's Avatar
Default 2009 chevy cobalt
im having problems also with my 2009 chevy cobalt when im driving my right headlight is very dim and at night when using my high beams i loose all power on that side my front signal will not work ive changed the bulb about five times just wasting money on that part so please if anyone knows how else to go about this please help its driving me crazy a car thats 3 yrs old should not be having these types of issues...
Old Aug 26, 2012 | 12:52 PM
unplug the r/f headlamp connector at the bulb
turn on the headlamp switch
with lowbeams on; do you have 12volts at the orange wire?
if yes plug the connector back in
provided an alternate ground for the light from the black wire.
If the light goes bright you have a resistance issue.
check the r/f marker bulb as its wired in series with the r/f headlamp...resistance there will drop voltage through the headlamp
Old Aug 30, 2012 | 1:33 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Lesley Finelli,
Has this issue been resolved? Have you had the vehicle inspected for this issue?
Please feel free to contact me privately with any questions or concerns.
I look forward to your reply.
Louis
GM Customer Service
Old Oct 5, 2012 | 3:08 PM
1ATony's Avatar
New User
Awaiting E-mail Confirmation
You could have a bad ground somewhere on your headlights.
Old Oct 5, 2012 | 3:19 PM
GM Fixer's Avatar
check for 12 volts / or bad ground
Old Jan 28, 2015 | 10:51 PM
tiny80's Avatar
Default Headlight
2006 Cobalt, headlights are dim when in bright mode. Anyone came across this issue, if so please advice.
wduffy01
Jul 5, 2023 8:34 AM
garyv990
Feb 11, 2015 9:52 PM
Robert67
Jul 29, 2011 6:42 AM
PatrickCairns
Uplander
May 31, 2011 9:00 AM
steve36
Cobalt
May 15, 2008 4:08 PM
