2011 Tahoe, Driver side wheel squeaking
Hey guys, I have a 2011 Tahoe with 191K miles on it. I took the wheel off over the weekend to try and diagnose a squeaking noise when driving. When rotating the wheel with no load sounds perfectly normal (thinking wheel bearing) but I've had wheel bearings go before and heard the roaring sound as they would go. Not hearing that, just hear squeaking with the window open. Seemed like it was when i would hit bumps but now it's all all the time when in motion and breaking doesn't change the sound. So not sure what to look at! Going to be doing a ton of driving over the next two weeks and don't want something to go bad while driving. Just trying to determine what I need to look at, or what it could be. The Wheel bearing is not the original, it was replaced before I bought the truck and I bought it with 89K miles on it. The passenger side bearing was replaced at 120K. So i'm thinking its about time for the driver side to be replaced again as it has about 100K (mostly highway miles). Any help is appreciated
No...I took breaks apart to verify the wear indicator wasn't causing it, would have been surprised if it was since I had just changed breaks last year and they don't have 12k on them yet. Really think bearing is going so bought it and will replace...has over 100k on that bearing so could be early stages.
So replaced wheel hub, could tell it was going but squeak is still there...not in suspension only hear it while driving. All new rotors and pads last summer, pads still have plenty on them so really confused. Have the AC Delco heavy duty pads and rotors on semi-metalic. Any thoughts???
Wolverine41086
March 11th, 2012 7:36 PM
