2011 Z71 Tahoe StabliAuto Braking System Issue
Old Jun 17, 2011 | 5:13 PM
brentlaborde's Avatar
Default 2011 Z71 Tahoe StabliAuto Braking System Issue
I have a 2011 Tahoe with a 6" suspension lift with 325/65/18 tires. About two weeks after the lift the auto braking would come on sometimes only when i make a slight turn to the left at about 40 miles hour. It might happen twice a day. The dealer does not know how to fix and the factory has seen this issue occure more than once on lifted or lowered vehicles. It is a shame that the company that installed the lift has a 2011 in white and has everything the same as mine and he is not experienceing it at all and never heard of it.
Can someone help!
Old Jun 17, 2011 | 6:10 PM
ChevyFreak's Avatar
Is your Tahoe throwing any codes (i.e. warning lights, messages on the DIC etc..)? I would start there first.
I am not sure exactly what the issue is here. Are you feeling a vibration in the brake pedal (i.e. ABS system) or more like tire rub?
If it is indeed the brakes, it could be a simple sensor replacement.
However, I would, more or less, lean towards something being wrong with the lift/tire size. Have you checked to see if any of your tires are rubbing? If the problem only occurs when turning to the left I would guess checking rub on the right front tire would be in order.
I do not know much about these types of issues, so I cannot be of much help. But, simply based on the information you have provided these are the things I would check first.
Hope that helps! Good luck!!
Old Jun 17, 2011 | 8:24 PM
Welcome to the forum.
Quite possible that they damaged a sensor or its wiring when they installed the lift.
Old Jun 17, 2011 | 10:48 PM
When i brought it to the dealer they found no code failure in the system. If the sensor is damage i would think that the Stablizerauto braking system would stay on are it would show a fault in the code system when you hook up the computer.
Old Jun 18, 2011 | 12:27 AM
Perhaps but if it was an intermittent that the system interprets as a call for ABS activation, then just maybe . . .
Remember Occam's Razor.
Old Jun 18, 2011 | 7:23 AM
I need help!!!!!!!!!!!!!!!!!1
bobbygrn24
Sep 26, 2015 5:04 PM
navy99nfo
Mar 6, 2013 9:49 AM
Gunshow25
Jul 27, 2012 11:52 AM
eisenhauer01
37
Mar 15, 2010 4:20 AM
Treenap
Sep 24, 2007 8:26 AM
