2014 Suburban rear washer fill location
Old Jun 9, 2024 | 7:38 PM
ECan's Avatar
Default 2014 Suburban rear washer fill location
Hello All,
Just moved up from my '01 Tahoe to a very nice '14 Suburban Z71. I've been going trough checking fluid levels and the one thing I can't find is the location for the tank for the rear window washer. I can hear the pump when I activate the back window wash but I don't get any fluid.
Thanks,
EC
Old Jun 9, 2024 | 7:49 PM
maybe the front and back use the same tank? Did you check your owner's manual?
Old Jun 9, 2024 | 7:56 PM
ECan's Avatar
I did and it makes no mention of a rear tank. Sec 10-22 speaks of how and what to fill with and makes reference to 10-6 which is the under-hood location map for fluid tanks. M is the windshield tank with no mention of dual purpose for the rear window and references 10-22 for filling instructions... A very GM infinite loop that leaves me searching for an answer here before I start trying to trace the hose to a pump/tank.
Old Jun 9, 2024 | 8:00 PM
Rednucleus's Avatar
I'll bet one tank services front & back. When you run the back pump, where do you here it? Our '20 Tahoe has only one tank for both
Old Jun 9, 2024 | 8:01 PM
ECan's Avatar
It sound like it is pumping from the back of the truck.
Old Jun 9, 2024 | 8:56 PM
so maybe the hose for rear is obstructed, or the nozzle, or the pump is worn out
Old Jun 15, 2024 | 8:39 AM
rick1025's Avatar
one tank/two pumps
Old Jun 15, 2024 | 5:02 PM
Mapercas79's Avatar
My 2015 suburban uses one tank for both front and rear
chevyjoe12
Apr 23, 2022 12:44 AM
Julz44
Feb 20, 2016 9:33 PM
JoeBlow
Nov 24, 2011 10:05 AM
rdc1534
Uplander
Nov 11, 2009 10:44 PM
bigtim
Feb 17, 2008 3:45 PM
