2014 Tahoe - Replaced object alarm module (Rear Park Assist) - now error
Old Dec 21, 2021 | 10:08 PM
peteguhl's Avatar
Default 2014 Tahoe - Replaced object alarm module (Rear Park Assist) - now error
Hi everybody - I did a couple searches to make sure this hasn't been brought up here and many, many searches on Google without any luck..
I have a 2014 Tahoe LS 4x4 that has had a slow battery drain that I've been unable to identify going on 3 years now and FINALLY figured out the guilty circuit using the
voltage drop test for the first time - turns out it was the OBS DET fuse. Rear parking assist was working with occasional fault and I removed the fuse overnight to verify battery drain was stopped and it did stop.
Today I replaced the object alarm module under the front passenger seat, replaced the 10amp fuse for the circuit, and verified the key out voltage drop was good (dropped to 0 volts a moment after connecting multimeter) on the circuit.
Now the problem - the DIC now shows "Service Park Assist" even after pulling the negative cable for 30 minutes. Does this module need to be programmed or do I have more hardware that has gone bad?
Thank you for taking the time to read this and in advance for any assistance.
-Pete
Old Dec 22, 2021 | 7:49 AM
repairman54's Avatar
Shop manual for my '11 says module needs to be programmed after replacement. Dealer has to do that. I would assume it needs to be linked to the BCM.
Old Dec 22, 2021 | 8:30 AM
peteguhl's Avatar
Good deal, ty very much! Time to give them a ring!
Update: I've just scheduled the programming with my dealer and the expected cost is $150 for anyone who happens across this thread in the future.
Last edited by peteguhl; Dec 22, 2021 at 8:50 AM. Reason: Additional info after scheduling with dealership
Rich2007Z71
Feb 6, 2020 1:59 AM
yoyodude
Mar 6, 2018 11:45 AM
muthaffer
Jul 24, 2017 12:30 AM
aFloodofBeer
Cruze
May 4, 2017 8:37 PM
william stewart
Traverse
Nov 30, 2014 9:06 PM
