2016 Suburban oil leak rear of vehicle?
Old May 11, 2023 | 1:03 PM
  #11
rjm60's Avatar
Originally Posted by KX5
I took it to a Chevy dealer. They are replacing the pinion seal but not the crush sleeve. Does anyone know if that is the proper Chevy procedure for a pinion seal repair? I am curious as to what their repair guide states for a pinion seal repair.
Yes - that is the proper repair. You cannot replace the crush sleeve without disassembling the axle (i.e. pulling shafts and removing differential carrier) since you would need to reset the bearing preload with a new crush sleeve. It is also not as trivial a repair as it may sound since removing the pinion yoke releases the pinion bearing preload. The pinion nut must be reinstalled at thd exact pkace it was, so it would need to be marked prior to removal so that the preload is re-established when reinstalled.
Old May 12, 2023 | 12:09 PM
  #12
KX5's Avatar
KX5
Thanks for the reply. Repair is holding at this point.
ChrisP
Trax
Feb 15, 2023 1:25 PM
Carterjohn1
Apr 23, 2022 12:35 AM
medina3
Sep 11, 2018 10:48 AM
Dangerously High
Jul 20, 2018 12:12 AM
grubbs11
2014 - 2018 (GMT-K2)
Aug 30, 2016 2:09 PM
