2017 Suburban 1500 with 3.08 rear end tow question
Hello all. I have a 2017 Suburban that is not equipped with the HD/Max tow package, so I知 limited to a max of 6000 pounds towing capacity (it has the 3.08 rear end). I anticipate I値l need the trans cooler and will install a trailer brake. I知 interested in hearing if anyone has experience at towing at/near the top limit of this vehicle痴 listed capacity. I知 currently interested in purchasing a travel trailer that weight apps 4600 (dry weight) with a hitch weight of 515 (dry). I値l also be traveling with 6 passengers (4 kids). Thanks in advance to anyone who痴 able to share heir experiences towing with a Tahoe/Suburban w/ the 3.08 rear end.
Hello all. I have a 2017 Suburban that is not equipped with the HD/Max tow package, so I’m limited to a max of 6000 pounds towing capacity (it has the 3.08 rear end). I anticipate I’ll need the trans cooler and will install a trailer brake. I’m interested in hearing if anyone has experience at towing at/near the top limit of this vehicle’s listed capacity. I’m currently interested in purchasing a travel trailer that weight apps 4600 (dry weight) with a hitch weight of 515 (dry). I’ll also be traveling with 6 passengers (4 kids). Thanks in advance to anyone who’s able to share heir experiences towing with a Tahoe/Suburban w/ the 3.08 rear end.
Always figure that your total weight will be more then you think it is, even if you dont hit hit snow, mud, ect. Doing both axles on a 4X4 is a bit expensive but if you have the dough, I guess you could do so.
Me? I would trade up to what I needed, or keep your transmission out of overdrive and up into maximum torque range, particularly on any uphills. Make sure you have the best brake shoes or pads you can buy as well. Good idea about the transmission cooler!
MMP, first a couple of questions. What experience do you already have towing something of that size ? How often and where, flatland, hills, mountains ? Yes you can add all the needed equipment you mention but don't forget about synthetic lubes everywhere. I would suggest this to find a dealer and hook one up to your truck for a test drive. You might decide to get a different truck that is better equipped for your use as you have 6 family members safety and comfort to be concerned about . Sure someone might say you'll be ok as is but after the sale its all on you. Find a local rv group and visit with them. Hope all this helps. *BW*
I tow a TT of about 4k lbs with my 2007 Tahoe with the 3.42 gears and the 5.3l. I have added the trans cooler. I haven't had any issues other then some sway due to the shorter wheel base of the Tahoe... Other then the trans cooler, the only other things I have added is the Tekonsha p3 brake controller, and the Husky WDH, the weight distributing hitch is a MUST. In hilly terrain I do stay in 3 , on flat road OD is fine, I have found the transmission stays cooler in 3. We have yet to do any mountainous areas.
