22's or 24's, GOT EM? PLEASE READ!
Old Dec 8, 2006 | 6:00 PM
  #11
5thgeartapped's Avatar
Default RE: 22's or 24's, GOT EM? PLEASE READ!
I am having this problem on my 07 that has a 4" lift, 18 inch wheels and 33" tires. I have a stabilitrak and braking issue when turning. Its annoying as hell as im sure you all know. Dealer told me only fix is to turn off stabilitrak on dash each and every time you get in the car. There has to be another or soon to be another way to fix this??
Old Dec 12, 2006 | 12:03 PM
  #12
bump
Old Dec 12, 2006 | 1:18 PM
  #13
vyslouzil's Avatar
his 24s are not 1/8" of is original 20s ...they are quite a bit bigger. Landon, I know superchips etc talk about 24 inch programming..but what does it actually mean? if its just speedo, its pointless.. personally i have never noticed an issue with stabilitrack, but the loss of DOD/AFM is what has always bothered me.
ORIGINAL: 73shark
To elaborate on what Dave said re: tire/wheel. If the OD of your 24" tire wheel package is within 1/8" of original, then there's no need to recal speedo as it basically sees no difference.
Old Dec 12, 2006 | 1:20 PM
  #14
vyslouzil's Avatar
btw, 22s with street tires are the same size as the stock 20s with the all seasons (thicker tires)
ORIGINAL: biglg
I just got my 24" wheels. I had previously talked to the dealer about updating my computer and runing Tech II. However today, I talked to the manager and he said that there isnt a GM VCI for anything larger than 20" wheels.
So, if you have 24's did your dealer do any programing to the vehicle? If so what did they do?
Old Dec 12, 2006 | 1:37 PM
  #15
biglg's Avatar
vyslouzil,
What air pressure are you running in your 24's???
Superchips will calibrate the speedometer, odometer, change the shift points, firm up shifts, and some other stuff. I had it on a hemi truck and i was actually amazed. I know Dave has said they just change things along the RPM band, but it sure felt better.
If you are missing that seat of the pants feeling I would get the superchips. I will probably get one after christmas is over and I have some more money to blow.
However, mine with the 24's doesnt seem to be any doggier! My tire size however is about 1.5% larger than the factory 20's overall circumfrance. Probably not a huge deal, but it is off more than I like it. At 60MPH I am actually going 59MPH, i ran a tire calculator online and it tells you where you are at.
Old Dec 12, 2006 | 1:54 PM
  #16
Black 5.3's Avatar
ORIGINAL: 5thgeartapped
your best bet would be to get HPTUNERS its a tuning program that gives you manual control of the parameters in the PCM/TCM.. then you enter the size of your new tires and you click on auto scale and it will change alot of stuff in your pcm and tcm like shift points/VSS cal/TPS/downshifting..
Old Dec 12, 2006 | 11:17 PM
  #17
CAn you offer me any more info on this, anyone else have opinions to this??
Old Dec 13, 2006 | 12:02 PM
  #18
Black 5.3's Avatar
http://www.hptuners.com/help/
read the help file its very well written and itll answer all your questions or once you get HPT just email me your file and ill tweak it for ya..
robertehess
Apr 21, 2011 2:01 PM
Terry Neff
Site Feedback
11
Apr 23, 2010 3:24 PM
CRFrizzell
Jul 6, 2007 11:13 AM
antmesa
Aug 28, 2006 3:35 PM
