3 questions: Navigation issues and real-time Fuel economy
Old Sep 4, 2014 | 8:17 AM
  #11
guillo987's Avatar
Originally Posted by 73shark
I'm guessing it's an antenna connection problem.
I'm sure the aswer is "no", but, there is a easy way to access this place where the antenna is connected, beside the vav system i guess or on the roof? Or is it the little ball on the dash?
A DIY procedure will be appreciate!
Old Sep 4, 2014 | 8:18 PM
  #12
Not sure what the vav system is but the Nav antenna is under the dash. Don't know how accessible it is.
The little ball is the light sensor that controls the auto headlights.
Old Sep 4, 2014 | 9:48 PM
  #13
The all knowing orb on the dash also provides input to the HVAC system if you have the digital system....
Its possible the antenna has come un plugged or if the vehicle is new to you but had a previous owner , they may have changed out the radio or figited with the cabling...
I'd suggest pulling the radio and checking the connections
Global Positioning System (GPS) Antenna
The GPS antenna is located in the upper center of the I/P. The GPS antenna is powered through the same coaxial cable used to send the signals to the NAV radio. Interference to the system may occur if any of the following exist:
• Signals are obstructed by objects such as, tall buildings or trees.
Metallic objects located on the dashboard
Aftermarket glass tinting has been applied to the vehicles windshield.
canucklehead
May 10, 2013 11:48 PM
jackrook
Jul 17, 2012 1:15 AM
ericp
Jun 16, 2012 7:06 AM
jfw432
Dec 10, 2010 6:47 PM
Siliconasp
Aug 31, 2009 1:25 AM
