350 TBI No Power to Fuel Pump, No Start
Old Mar 1, 2023 | 6:47 PM
Karnawgie's Avatar
Default 350 TBI No Power to Fuel Pump, No Start
I recently bought an 88' Suburban with a 350 TBI in it. I drove it home and had started it up a couple times move it to where it resides now. It needed a head and intake gasket replacement. I've spent the last couple weeks doing so and reassembling pretty much everything besides some brackets and little bolts. I went to start it up and the fuel pump wasn't being activated.
I tried switching ground location for 2 wires from one spot to another on the head, then settled on an intake manifold bolt. These never changed the result of about 0.3-1.3 volts from the orange wire on the harness to the FP relay. I even tried splicing in a wire to the ground wire from the battery to rule out a bad ground. There's a little jumper from the red wire on the harness to the relay, so I jumped it and the fuel pump started up. I let it prime and cranked it over awhile and never got anything. I never even smelt any gas in the throttle body. It will run off starting fluid, but no fuel is going through the injectors.
I am getting 12 volts from the ECU at the orange wire beside the tan and white one, (these wires are beside each other on the harness to the relay). And I checked the 4 wires coming from the little bus bar on the firewall, and they all carry 12+ volts, idk if any are fusible links. All of the fuses under the dash are okay, including the inline fuse under the hood.
I hope and assume it's a couple simple fixes. Any input would be really really appreciated, thanks.
John Bolling
1988 - 1998 (GMT400)
Oct 1, 2020 11:09 AM
cameron.bunch
Mar 17, 2020 4:15 PM
simpsonracing
Mar 19, 2013 3:37 PM
kidster
Mar 22, 2009 11:13 PM
seankeppers
Jan 29, 2009 10:56 PM
