3rd row bench seat stuck in upright position,,,need help lowering to get it out
Hi guys, I looked but could not find a solution in my search.
I have an 07 Sub with a 3rd row split bench seat. The one side folded and pulled out with no problem. However the other side feels as if there is no cable tension to release the back to fold down. As many already know, if you don't have the back folded, it will not unlock to where you can release it from the floor to remove.
I have a long trip planned and need to pack the rear with cargo, dog, etc.
So if there is a quick and/or easy solution to either folding the seat to remove it, or just a way to remove it with the back in the upright position, I'd greatly appreciate the help.
TIA
TIA
No replies, and I still have the problem. I took it to a couple of places, and no one seems to know how to even get at the area where the cable is located to lower the seat so it can be pulled out.
ANYONE have this problem or know the fix?
My daughter had a similar problem with the third row seats in her 2004 Denali. I took it to the dealer and the guy worked on it for about 30 minutes before he was able to unlatch it. No charge.
As I have said in the past, a good relationship with the service department is priceless.
I just wish I knew what the trick/fix is. The area that has a cover where presumably the release cable runs is up against the interior of the truck. If the cable is broken or has come loose, I have no clue how to get to it with the seat in place.
Wrong. Imagine someone buckled into a seat that is not latched to the floor properly. that's the purpose of designing this safety feature.
if it is will not release, and is engaged properly, you will have to access the cables to be able to lower the seat or removal. Use the seat you can remove as a guide. It will be difficult.
I understand exactly what the problem is as I have had to fix the same problem.
typically, someone raises the seat up, pushing on the wrong lever. This partially unlatches the front clasps locking the seat in the up position. If the front is latched in properly and its still locked...you will have to access the cables that move the levers to allow the seat to lower.
