3rd row bench seat stuck in upright position,,,need help lowering to get it out
Old Nov 22, 2013 | 2:34 PM
Vector1's Avatar
Question 3rd row bench seat stuck in upright position,,,need help lowering to get it out
Hi guys, I looked but could not find a solution in my search.
I have an 07 Sub with a 3rd row split bench seat. The one side folded and pulled out with no problem. However the other side feels as if there is no cable tension to release the back to fold down. As many already know, if you don't have the back folded, it will not unlock to where you can release it from the floor to remove.
I have a long trip planned and need to pack the rear with cargo, dog, etc.
So if there is a quick and/or easy solution to either folding the seat to remove it, or just a way to remove it with the back in the upright position, I'd greatly appreciate the help.
TIA
Old Dec 14, 2013 | 12:08 PM
Vector1's Avatar
Question
No replies, and I still have the problem. I took it to a couple of places, and no one seems to know how to even get at the area where the cable is located to lower the seat so it can be pulled out.
ANYONE have this problem or know the fix?
Old Dec 14, 2013 | 12:56 PM
try pushing on the back of the seat to engage the front clasps. if they are not locked in properly, the seat is designed to not lower.
Old Dec 14, 2013 | 1:35 PM
My daughter had a similar problem with the third row seats in her 2004 Denali. I took it to the dealer and the guy worked on it for about 30 minutes before he was able to unlatch it. No charge.
As I have said in the past, a good relationship with the service department is priceless.
Old Dec 17, 2013 | 9:06 AM
Vector1's Avatar
Well lets assume it is not seated/locked in properly. In theory that should not have anything to do with the ability to lower the backrest, correct? Mine will not fold down no matter how much I try to push/shake it while trying to lift the release for it to fold. Without it being folded down, I think there is some type of clap that will not release to let the seat be removed.
Maybe your daughter is cute and that is the reason they helped her for free. Any dealer near me will not have a mechanic take a half an hour to fix something for a customer without charging for it.
I just wish I knew what the trick/fix is. The area that has a cover where presumably the release cable runs is up against the interior of the truck. If the cable is broken or has come loose, I have no clue how to get to it with the seat in place.
Old Dec 17, 2013 | 10:23 AM
Since I took it in I don't think my daughters looks had anything to do with it.
Old Dec 18, 2013 | 6:53 AM
Wrong. Imagine someone buckled into a seat that is not latched to the floor properly. that's the purpose of designing this safety feature.
if it is will not release, and is engaged properly, you will have to access the cables to be able to lower the seat or removal. Use the seat you can remove as a guide. It will be difficult.
Old Dec 18, 2013 | 4:48 PM
Vector1's Avatar
I know you are only trying to help so I must be explaining this wrong. One of the two 3rd row seats is locked into it's position without and wiggle room. Another words it is seated properly. Since the sequence for getting it out requires lowering the backrest first, that is where the problem is. If I could lower the backrest, step two could be accomplished so I could lift the seat out once it is folded. Trouble is that the backrest will not fold forward, and the latch that releases it feels like there is no tension.
Old Dec 18, 2013 | 8:20 PM
I understand exactly what the problem is as I have had to fix the same problem.
typically, someone raises the seat up, pushing on the wrong lever. This partially unlatches the front clasps locking the seat in the up position. If the front is latched in properly and its still locked...you will have to access the cables that move the levers to allow the seat to lower.
Old Dec 19, 2013 | 10:09 AM
Vector1's Avatar
That is the dilemma, and I cannot figure out how to get to that area with the seat up against the side of the interior. There must be a way but I am not sure how to do it.
