3rd transmission in 2007 ltz tahoe 4x4
Old Nov 2, 2011 | 5:17 PM
  #21
kywill's Avatar
Originally Posted by ousig2408
. that 1990 has a 3 speed d
its got over drive on it. the tahoe i agree pulls better its just frustrating that it keeps having these issues but i ordered a B&M cooler kit today so hopefully that will drop my temp in the tranny
Old Nov 2, 2011 | 8:43 PM
  #22
150 70# bales is over 10,000 lbs which is more than 3,000-4,000 lbs over the 07 tow rating depending on axle ratio and 2WD or 4WD. Might explain why you're lunching trannys so quick.
Old Nov 2, 2011 | 8:59 PM
  #23
kywill's Avatar
yeah that might have something to do with it and i have the 4wd model
Old Nov 2, 2011 | 9:03 PM
  #24
kywill's Avatar
ok so i just did the math and your right with the bobcat trailer and 150 bales of hay im at about 13500 pounds.................... i think i need to get a 3/4 truck.........
Old Nov 3, 2011 | 11:36 AM
  #25
ousig2408's Avatar
ummm yes no 1/2 ton stock truck/suv can handle this weight for much time at all
or make 2 trips at 75 bales per trip (if it isnt too far of a trip)
Old Nov 18, 2011 | 8:19 AM
  #26
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> The 2007 Tahoe specs: Horsepower: 320 hp / 239kW @ 5200, Torque: 340 lb-ft / 461 Nm @ 4200 rpm, Max engine speed 6000 rpm
Louis
GM Customer Service
Old Nov 18, 2011 | 9:25 AM
  #27
kywill's Avatar
yeah im starting to realize that now because the current tranny is cooked i have 1 and a half forward gears and reverse. do they make a beef up kit for these trannys?
Old Nov 18, 2011 | 12:51 PM
  #28
ousig2408's Avatar
like we have all said - if you want to pull that much weight you need a 3/4 ton vehicle or something designed to haul this much weight. the 1/2 ton Tahoe is not what you need or should use safely in your current situation
Old Nov 19, 2011 | 10:31 AM
  #29
vrso2's Avatar
hmmm, i have similar experience. But i'm not towing guy I have second tranny on my 07 burb LT. First one break on me in 64k, year ago. Dealer replaced tranny for brand new with 100k or years warranty. So now i'm good for another 5 years or 80k
Old Nov 19, 2011 | 7:45 PM
  #30
silveroak94's Avatar
When it came time to replace the last Suburban, I upgraded to a 3/4 ton (a 2007). They're harder to find than the 1/2 ton version, but everything on it is beefed up and the ride quality and comfort level are the same. My biggest complaint with my old one was the lack of power. The new one--with a 6.0--just plain hauls ***. As a bonus, I think I'll avoid some of the problems with the 5.3 liter engine I've been reading about on here.
____________________
1988 Mercedes Benz 560SL (Wife's)
1998 Mercedes Benz S420 (Wife's)
1995 Mercedes Benz C280 (Daughter's)
2007 Chevrolet Suburban K2500 3LT (MINE!) <!-- / message -->
abluhm23
Mar 17, 2011 8:27 AM
aubiexx
Dec 18, 2010 5:21 AM
LiveHuge
Nov 19, 2008 8:27 PM
itchy2000
Mar 1, 2007 1:27 PM
