-40 C 1996 K2500 SUB won't start
Old Dec 22, 2008 | 8:10 PM
ussva's Avatar
Default -40 C 1996 K2500 SUB won't start
It got to -40 C. I tried starting it for the day, no luck. So, I pulled it into my friend's heated big log truck garage and let it thaw out, still no start. Day 2, Changed plugs and oil.It was flooded...Smell of gas in the oil and wet plugs. Cranked it over without plugs to get rid of any fuel in the cylinders. Let it sit overnight. Day 3, thought it would start right away. No such luck, Battery is good, fuel is getting to injectors, there is spark from sparkplugs.....WTF!!!!!!
Sensor? Any help would be greatly appreciated....Can't afford to take it to a garage right now.
[/align][/align][/align]Oh yeah, new Cat converter, new air filter, 6 month old fuel filter.....help!!!! [/align][/align]Oh yeah, it's a 7.4 litre 454....... [/align][/align][/align][/align][/align]***Moderator edit: Merged consecutive posts.PLEASE use the edit feature. Its there for a reason. Just click [/align]
Old Dec 22, 2008 | 8:13 PM
ussva's Avatar
Default RE: -40 C 1996 K2500 SUB won't start
Old Dec 22, 2008 | 8:24 PM
ussva's Avatar
Old Dec 22, 2008 | 10:12 PM
EvansBlue's Avatar
Your timing chain is out of time. [/align][/align]
Old Dec 23, 2008 | 1:19 PM
ussva's Avatar
You think it's the timing? Would that have changed because I tried cranking over while cold?
Old Dec 26, 2008 | 9:16 AM
ussva's Avatar
Is this procedure going to be difficult to do? Doesn't look like it has a distributor, flat box with the plug wires plugged in.
Old Jan 25, 2009 | 9:19 PM
ussva's Avatar
Had nothing to do with the timing. Cleaned contacts on sensors, it was the anti-freeze sensor. What happened to the dependable computerless engines, carburators etc.....?
Old Jan 25, 2009 | 9:26 PM
ussva's Avatar
Starts fine in terms of engine, but, starter is gone now from cold cranking with battery boost/charger set at boost 60 amp.
ussva
Mar 18, 2010 10:07 PM
jrsavoie
Feb 24, 2010 2:38 PM
ussva
Jun 19, 2009 6:58 PM
chadpeyton
Mar 8, 2009 8:02 PM
ussva
May 16, 2008 10:33 AM
