4l60e problem
Old May 2, 2013 | 8:48 PM
lucasjames's Avatar
Default 4l60e problem
my trans on my 99 burn won't start off in 3rd or drive it will shift through all gears but only if its 10mph an up slips in 1st if I get on it plz help
Old May 2, 2013 | 9:05 PM
Brok's Avatar
I have a 4T65e Transmission and it is the upgraded model of yours but is about 99 percent similar. Rewrite that a little better and maybe I can offer you some help and tell you how to fix it. As you write it though I can not understand a lot of it. No start 3rd or drive. Ok get that part, shifts all gears but only 10mphs??? The last part I totally can't make out.
Old May 2, 2013 | 9:09 PM
Brok's Avatar
Or is that a 4L60E transmission you are referring to? Either one I can diagnose for you as my books long covered every model of transmission. I just need more solid type questions and statements to help. I can tell you more or less from what I read some ideas but would prefer better writing if you need help.
Old May 2, 2013 | 9:29 PM
lucasjames's Avatar
ok it a 99 k1500 suburban 5.7 it won't move in drive or 3rd from a stop but it moves in 1st and 2 . If I am driving over 10 mph and shift it to drive it will shift through all gears
Old May 2, 2013 | 9:44 PM
Brok's Avatar
I assume you are referring to drive as overdrive not just general since you said you can start in first and 2nd. That is quite questionable as you say you can obtain the other gears which is odd. I know that if you have only 1st and 2nd gear your (B Solenoid stuck on) If there is foreign material in the solenoid, the PCM signal is grounded or the solenoid return wire to ground is pinched, check the 2-3 shift solenoid ON failure. Can you offer anymore to what your problem is or is that all you can see right now? The more you know the more I can help you on this. You could have bad fluid and filter, your 2-3 shift valve or the 3-2 manual downshift valve is stuck, nicked or, damaged, then you have to check the control valve assembly. There's a few other reasons I can list as well that follow into those guidelines of a NO 2-3 shift. The more you can offer the more I could help assist though.
Old May 2, 2013 | 9:54 PM
lucasjames's Avatar
I changed the filter and fluid old fluid wasn't burnt was going to Change the shift solenoid but got wrong ones...havent changed them yet cuz trans fluid is not cheapit says to put bex 6 or could I yes something else
lucasjames's Avatar
dex 6
Brok's Avatar
30 Common 4L60E Transmission Problems & Repair | Charlotte NC Here is one online site that I know of that offers common problems to your Transmission which you could check out and see if those are any issues you had or could have. They also list how to fix them as well.
Old May 2, 2013 | 9:56 PM
lucasjames's Avatar
sorry im on my phone and it auto corrects sometimes
Old May 2, 2013 | 10:12 PM
Brok's Avatar
If you have all the proper equipment and can get the transmission out or can get to the valve body side easy I would try replacing the shift solenoid first. Easiest way to check if they are bad is to run to jumper wires to your battery positive and ground and run the other side to the positive side and ground side of your solenoid and see if it clicks. It could also be stuck as well. Either way if it is stuck or sticking I would replace it and more or less replace any other solenoids as the kit is only around 80 dollars typically and saves you the headache of having to dig into that side again for another minor solenoid especially if the 1-2 shift solenoid goes next or the EPS or that.
flewster
Jul 28, 2021 2:20 PM
k_grantham10791
10
Jan 11, 2014 1:18 PM
abqgolfer
Aug 27, 2011 11:30 PM
Billytk
Jan 15, 2010 8:07 AM
cjk04
Aug 13, 2009 7:14 PM
