4l60e Question
Old Jan 23, 2010 | 6:44 PM
Burbanator10's Avatar
Default 4l60e Question
Hey guys new to the site. Benn reading yalls stuff for quite some time now. Seems to be lots of knowledge here. SO here we go! I have a 1993 suburban that the tranny is messed up in, my question is will the tranny out of a 98 suburban work in the 93? I know they are both 4l60e's. Thanks a bunch guys.
Old Jan 23, 2010 | 7:08 PM
nauticstar87's Avatar
If they are both 4l60e, then you should have no prob. Just be sure you have a 4l60e in the 93 and not a 700r4.
Old Jan 23, 2010 | 7:21 PM
If i look under the suburban how can i tell the difference between the two?
Old Jan 23, 2010 | 7:35 PM
If you look at the side of the trans on the passenger side, behind the filler tube, if theres a cable running from there to the throttle linkage its a 700r4, thats called a T.V. cable and its the worst invention known to the automotive kind... In my opinion. On the 4l60e instead of a t.v. cable, there should be an electrical connection in its place.
Old Jan 23, 2010 | 7:49 PM
Ok i took this picture. And actually im thinkin now that its a 700? In this picture is that the vaccum line you were talking about? THanks Alot for the help
Old Jan 23, 2010 | 8:12 PM
That looks like the cable for a 700. It's a transmission valve cable. It keeps line pressure up in the trans, and is also the reason i blew up 12 or 13 700r4s when i was 16. Hopefully someone else will chime in on this. I don't have a lot of expierience with the 4l60e. But all the pictures I've looked up on google tonight of a 4l60e have nothing like that pic you have, they all have a electrical connection in place of the cable.
Old Jan 23, 2010 | 8:41 PM
emzornes's Avatar
I believe that is a 700R4 and not a 4l60E, I think the 4l60E did not come out until late 94 early 95 modles.
Old Jan 23, 2010 | 8:51 PM
Thats what i was thinking to. I'm pretty sure it was late 94, but I have seen many 4l60e swaps. Apparently it's not to difficult. I've never done it though.
tloftus
May 19, 2024 6:19 PM
Grim904
Sep 5, 2012 8:08 AM
abqgolfer
Aug 27, 2011 11:30 PM
nrenee918
Jan 15, 2010 8:50 AM
mygreenihc
Aug 30, 2009 10:34 PM
