84 Suburban oil pressure switch connector
Old Nov 26, 2010 | 8:00 PM
84bowtiemonster's Avatar
Default 84 Suburban oil pressure switch connector
the oil pressure switch connector im my 1984 suburban is cracked causing a major oil leak. the dealer and parts houses told me i have i to do a junk yard or parts car in order to replace the connector. its a part i must pull my self and its too cold for going from junk yard to junk yard...in addition to the fact that it might be bad as well.
is there another fix for this? aftermarket swtich, gauge and wiring?
Old Nov 26, 2010 | 9:40 PM
Welcome to the forum.
I'd remove the defective sensor and replace it w/ a plug of the correct size while searching for a new sensor. Have you tried on-line? If you can get a P/N, it will make your search a lot easier. Your parts dept should be able to give it to you even if it's no longer carried.
Old Nov 26, 2010 | 9:43 PM
i can get the oil pressure switch anywhere. i need the electrical connector that attaches to it. ive been searching online all day lol
Last edited by 84bowtiemonster; Nov 26, 2010 at 9:57 PM. Reason: left something out
Old Nov 26, 2010 | 10:00 PM
would a bolt be a suitable plug?
Old Nov 26, 2010 | 10:01 PM
Are you saying the connector on the wiring harness needs replacing? I misunderstood. I thought it was the connector on the sensor that was bad thereby causing the leak.
A pair of wire cutters and trip to a salvage yard should yield a connector.
Old Nov 26, 2010 | 10:13 PM
yes the connector on the wiring harness. i did 3 salvage yards this morning. i found one and it was actually on a blazer. only one lot had an older suburban on the lot and there wasnt much left of it.
i bought the one i found and installed it and it still leaking. it doesnt seem to fit all the way onto the switch but it appears to be the same connector as the one that i removed. and i know that some of the suburban and blazer parts are interchangeable.
it doesnt appear to be any damage to the oil pressure switch itself but should i replace it also?
Old Nov 26, 2010 | 10:20 PM
Not sure how the wiring harness connector could cause a leak in the sensor.
Does the sensor not leak if the connector is not connected?
Old Nov 27, 2010 | 11:15 AM
2wd-K5's Avatar
the sending unit is whats causing the leak, an electrical problem shouldnt cause an oil leak...
Old Nov 27, 2010 | 5:32 PM
My thoughts exactly.
Old Nov 27, 2010 | 8:31 PM
DoubleO7's Avatar
Switch looks like this, right?
The plastic part that the spade terminal comes out of is not sold separately.
(The part beyond the metal hex)
panzaa
Jun 22, 2014 5:06 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
geozeke
Sep 16, 2009 7:50 AM
rtszolis
Feb 9, 2008 8:45 AM
dark_waters
May 17, 2007 11:51 AM
