87 suburban - runs for 5-10 seconds and dies
Old Sep 1, 2012 | 3:01 PM
boosh's Avatar
Default 87 suburban - runs for 5-10 seconds and dies
I was driving down a dirt road on a rainy day and ran through a puddle that was a little too big. It died after going through it. I got it to fire again, but it died quickly after. I had it towed back to the house and let it dry for 2 days. Now i can get it to fire and idle (although poorly) but it dies 5 - 10 seconds later. just dies. no throttle response, its like someone turned the key off. I checked the distributer for water - dry as a bone. everything else seems to be in order...
any help is appreciated.... i gotta use this thing to move into my new house this weekend.
87 R20 suburban 454 2wd silverado
Old Sep 1, 2012 | 4:34 PM
Check air filter, may have ingested some water.
Old Sep 1, 2012 | 5:05 PM
boosh's Avatar
took off the air filter to find a little bit of wetness on the filter itself, but no standing moisture on the throttle blades the air filter housing was wet, but any water that had gotten in would be pushed out after being cranked up and ran even for a few seconds, no?
Old Sep 1, 2012 | 5:43 PM
boosh's Avatar
So, I took the air cleaner off and watched it when it died. The fuel cuts off. I just replaced fuel sending unit/fuel pump and the fuel filter. What could make it stop getting fuel like that?
Old Sep 1, 2012 | 5:50 PM
If you used a non-OEM part, the new one could be bad. Is it a TBI system?
Old Sep 1, 2012 | 8:56 PM
boosh's Avatar
I replaced it a few months ago... Worked fine up until the puddle. It's the oem Delphi part. And yes - TBI system.
BigZachsHouse
Corvette
Aug 15, 2012 9:03 PM
sneed1029
Apr 16, 2012 9:42 PM
chon41017
Dec 5, 2011 7:26 PM
utdad
Apr 7, 2008 8:17 PM
