95 K-1500 Rolls when in park
Old Aug 9, 2021 | 5:38 PM
mota32's Avatar
Default 95 K-1500 Rolls when in park
my (5 Suburban rolls when in park. Starts fine and shifts into every gear normally but when I put it up in park the transmission isnt in reverse and key off is possible but when you let off brake pedal it will roll away. I have tried the linkage adjust procedure where you release the clip and shift from park to 1st gear 4 times then close clip back but still the same result. please help
Old Aug 9, 2021 | 6:01 PM
park pawl linkage in the trans may be broke. you could try to drop the pan to see if there is anything you can access. if not, may require a teardown....make sure the ebrake is functioning.
Jeremy1990
2007 - 2013 (GMT900)
Apr 30, 2022 9:34 PM
bluelimo
1988 - 1998 (GMT400)
Jul 11, 2017 10:49 PM
dannyr424
May 29, 2014 1:00 PM
Rallysporter101
Camaro
Feb 11, 2010 7:33 PM
bdawg0958
Nov 5, 2007 3:55 PM
