95 Tahoe AC noise
Old Sep 17, 2007 | 2:35 PM
mfrohlich's Avatar
Default 95 Tahoe AC noise
I have a 95 Tahoe that has a noisy AC compressor. My guess is that it is a bad bearing or clutch mechanism. It is noisy on start up, but goes away after running a while. Any thoughts or suggestions? Can you just replace the bearings or clutch mechanism?
Thanks for the help.
Old Sep 18, 2007 | 9:42 AM
ZX1100F1's Avatar
Default RE: 95 Tahoe AC noise
Does it sound like marbles clattering around not loud enough to hear inside the cab?
If so; it is a common noise that does not usually always indicate failure is immanent.
The bearings are not user serviceable.
I would run it until it fails, I have seen them go forever making this noise.
Old Sep 18, 2007 | 10:10 AM
mfrohlich's Avatar
No, it is definitely audible from the cab and surrounding area. It gets less as the vehicle runs, and then it will stop once the vehicle has been running for a while. The sound is more screechy, and does not speed up as engine rpm goes up. Is this the clutch?
Old Sep 18, 2007 | 2:08 PM
ZX1100F1's Avatar
Ahhh. OK sounds like it could be the clutch or the compressor bearings or possibly a slipping belt but that usually occurs when the pulley becomes hard to spin due to bad bearings.
If you don’t want to have a shop complete the repairs then you could try replacing the clutch and belt and if that does not solve the problem then the compressor is most likely going south on you.
My best guess is a faulty compressor due to the noise not changing pitch with the RPM’s.
Old Sep 22, 2007 | 10:47 AM
Chevy JH's Avatar
I have a 1995 Tahoe doing the same thing, My service dept. manager says the comp. is going due to bearing failure. Mine smokes too when a/c is engauged. Needless to say winters coming, it'll stay like that for a while.
Gman
Feb 29, 2024 12:49 PM
leethedeuce
May 16, 2014 7:08 PM
biglg
Oct 16, 2006 1:05 PM
john68
Jul 19, 2006 9:10 PM
usrrree
May 14, 2006 11:03 AM
