95' tahoe HELP!!
Old May 26, 2010 | 8:30 PM
muckd4t's Avatar
Default 95' tahoe HELP!!
i just recently bought a 95 tahoe lt 4 dr. its in great shape but its got some issues.
first off, blinkers dont blick they stick on( i have to turn them off and on to make them work, i turned the flashers on and those blink but not the actual blinkers. When i turn it on the volt gauge drops a lil)
second, only the driver side window control works all windows( each window works just ONLY from the drivers side switch) any ideas??
i dono if this is a typical chevy issue but i figured i would ask the community and see what help i can get. thanks in advance and ill get back with updates
Old May 26, 2010 | 8:41 PM
Welcome to the forum.
Someone here should be able to lend a hand.
Old May 26, 2010 | 8:45 PM
maxxman04's Avatar
turn signals: i would check the flasher unit and all the bulbs.
window switch: look on the drivers door panel where switches are. just in front of them there may be a single switch with a pic of window printed on this. this switch locks out the other windows so they can't be operated independently. only the drivers door switches will work. if this switch is on your panel, and if my memory serves right, there are two window pics, one full window, one full window crossed out. set this switch to the full window not crossed out.
Old May 26, 2010 | 9:10 PM
muckd4t's Avatar
now dumb question where is the flasher located? i lookd on the fuse panel itself and i found a square relay that looks like the flasher but not 100% sure,
im going to go check out that window switch and let you know thanks though
Old May 26, 2010 | 9:23 PM
maxxman04's Avatar
down by the floor, drivers side, just above where your left foot would rest is a panel, bout 6" by 6", it will have various wires coming out of it, with a couple or few relays. if not there, then underhood. grab owners manual, or a chilton's or haynes manual.
Old May 27, 2010 | 5:05 PM
muckd4t's Avatar
i have the window switch in the unlock position and thats the only switch that will work so i dono if i have 3 bad switches or have messed up wiring somewhere
im still looking into the blinker situation
luni1974
Apr 29, 2014 2:31 PM
josh46970
Jul 28, 2011 12:19 AM
vwwebb
Jan 23, 2011 5:03 PM
kenney
Jan 31, 2009 5:29 PM
jharper
Dec 11, 2007 4:15 PM
