96 suburban
Old Aug 27, 2014 | 5:59 PM
samdimaio's Avatar
Default 96 suburban 1500, 350V8, 137K miles, cranks but wont start first start of the day
orig. engine/trans.
cranks fine, but wont start on first start of the day unless I use starting fluid. after first start, all other starts that day are good. does not stall. confirmed spark is good. opened the schraeder valve on the manifold - fuel squirts out good, but still feels like its not getting fuel on first start.
Last edited by samdimaio; Aug 27, 2014 at 8:06 PM. Reason: not enough info. provided
Old Aug 28, 2014 | 6:02 AM
RichC10's Avatar
Sounds like your fuel pressure is bleeding off overnight. The usual problem is the check valve on the fuel pump in the tank. Rent or borrow a pressure tester and leave it hooked up all night. If the pressure bleeds off you have two options. Either replace the fuel pump, or install a check valve in the fuel line as close to the tank as you can get it.
Old Aug 28, 2014 | 7:38 AM
samdimaio's Avatar
thanks for the advice, will check it out
Old Aug 28, 2014 | 9:15 PM
Rednucleus's Avatar
Wouldn't the pressure come back up as soon as the key is turned energizing the fuel pump?
Old Aug 29, 2014 | 6:19 AM
RichC10's Avatar
After the key is turned on it takes 10 seconds or so to build pressure, then it should start normally. Its just annoying to have to wait....
