96 suburban
orig. engine/trans.
cranks fine, but wont start on first start of the day unless I use starting fluid. after first start, all other starts that day are good. does not stall. confirmed spark is good. opened the schraeder valve on the manifold - fuel squirts out good, but still feels like its not getting fuel on first start.
Last edited by samdimaio; Aug 27, 2014 at 8:06 PM. Reason: not enough info. provided
Sounds like your fuel pressure is bleeding off overnight. The usual problem is the check valve on the fuel pump in the tank. Rent or borrow a pressure tester and leave it hooked up all night. If the pressure bleeds off you have two options. Either replace the fuel pump, or install a check valve in the fuel line as close to the tank as you can get it.
